[Proj] armenian coordinate system
Giuseppe Naponiello beppenapo at gmail.com
Tue Apr 6 06:48:19 PDT 2010
Hi Markus,
> > How to add towgs84?
> Copy-paste from my previous email :) Or try this (store as .prj file):
> I've tried this:
epsg_tr.py -wkt 2498 PROJCS["Pulkovo 1942 / Gauss-Kruger CM
45E",GEOGCS["Pulkovo
1942",DATUM["Pulkovo_1942",SPHEROID["Krassowsky1940",6378245,298.3,AUTHORITY["EPSG","7024"]],TOWGS84[23.9,-141.3,-80.9,-0,0.37,0.85,-0.12],AUTHORITY["EPSG","6284"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4284"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",45],PARAMETER["scale_factor",1],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","2498"],AXIS["X",NORTH],AXIS["Y",EAST]]
and I've this error:
  File "/usr/bin/epsg_tr.py", line 153, in <module>
    elif int(arg) > 0:
ValueError: invalid literal for int() with base 10: 'PROJCS[Pulkovo 1942 /
Gauss-Kruger CM 45E,GEOGCS[Pulkovo
1942,DATUM[Pulkovo_1942,SPHEROID[Krassowsky1940,6378245,298.3,AUTHORITY[EPSG,7024]],TOWGS84[23.9,-141.3,-80.9,-0,0.37,0.85,-0.12],AUTHORITY[EPS'
What wrong ?
-beppe-
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100406/562885fe/attachment.html>
