[Proj] Point Scale factor service
Brent Fraser bfraser at geoanalytic.com
Thu Apr 22 09:42:21 PDT 2010
Fair enough.  So how about:
int pj_pointscale( ProjPJ prj, double lon, double lat, double azimuth, double
*pointscale );
Brent
Noel Zinn wrote:
> Someone more knowledgeable than I in proj4 will have to comment on your
> syntax.  My point is that if WGS84 ellipsoidal coordinates are used with
> spherical Mercator formulas as Google are doing (a=b=6378137), then the
> result is a non-conformal projection (point scale factor not the same in all
> directions).  If you plan to use scale factors, you need to compensate for
> azimuth.  The scale factors (as functions of azimuth) have been quantified
> in EPSG Guidance Note 7-2 (www.epsg.org).  -Noel
> -----Original Message-----
> From: proj-bounces at lists.maptools.org
> [mailto:proj-bounces at lists.maptools.org] On Behalf Of Brent Fraser
> Sent: Thursday, April 22, 2010 8:51 AM
> To: PROJ.4 and general Projections Discussions
> Subject: Re: [Proj] Point Scale factor service
> Yikes!  I've been using
> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
> +k=1.0
> +units=m +nadgrids=@null +no_defs
> as the definition.  Should I be using something else?
> Brent
> Noel Zinn wrote:
>> FYI, Google's "Web Mercator" is not truly a Mercator (nor is it spherical)
>> because it is not conformal.  Point scale factor varies as a function of
>> azimuth.  -Noel Zinn
>> Sent: Wednesday, April 21, 2010 1:39 PM
>> Subject: [Proj] Point Scale factor service
>> Lately I've run into issues regarding scale.  The need to:
>>    - measure a distance on a web map application
>>    - show layers based on map scale
>> In the past, I've carefully selected a good projection (and parameters) to
>> minimize these problems.  These days, the standard is Spherical Mercator
>> (thank
>> you Google), and most applications ignore the map projection's point scale
>> factor at the location/view of interest, or do their own hack to estimate
>> it.
>>     I thought a more robust solution would be to have a function in proj
> to
>> return the point scale factor at a location, something like:
>>    int pj_pointscale( ProjPJ prj, double lon, double y, double *pointscale
>>        (return FALSE if not available for that projection?)
>> The calling applications could then do something useful with that
>> information.
>> Thoughts?
>> Best Regards,
>> Brent Fraser
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
> Proj mailing list
> Proj mailing list
