[Proj] where is the default origin ?
    Randy
    randyqiuxy at hotmail.com
    Wed Apr 28 07:05:09 PDT 2010
Hi list,
I'm new here, and know little about projection in GIS.
I'd like to know where the default origin is when I do Mercator
projection like this:
from "+proj=latlong+ellps=WGS84+datum=WGS84"
to   "+proj=merc+lat_ts=30+ellps=WGS84+datum=WGS84+unit=meter"
I just know the default origin is the point of intersection with
greenwich and equatorial when I use the default latitude of true
scale,but if now the latitude of true scale is decided by "lat_ts",where
is the default origin?
Thanks a lot!
Best regards,
Randy
More information about the Proj
