[Proj] Projection doesn't use +towgs84 parameters
Dražen Odobašić dodobasic at gmail.com
Mon Aug 2 06:27:19 PDT 2010
i'm having an issue with transformation between two coordinate systems
using cs2cs. I've noticed this while trying to use gdalwrap, but using
cs2cs has same results.
This is what im trying to execute:
cs2cs +proj=tmerc +lat_0=0 +lon_0=15 +k=0.9999 +x_0=5500000 +y_0=0
+ellps=bessel
+towgs84=514.0188,155.448,507.0461,5.6136,3.676,-11.4667,0.9999979090043
+units=m +no_defs +to +proj=tmerc +lat_0=0 +lon_0=16.5 +k_0=0.9999
+x_0=500000 +ellps=WGS84 +units=m +no_defs -v
# ---- From Coordinate System ----
#Transverse Mercator
#       Cyl, Sph&Ell
# +proj=tmerc +lat_0=0 +lon_0=15 +k=0.9999 +x_0=5500000 +y_0=0 +ellps=bessel
# +towgs84=514.0188,155.448,507.0461,5.6136,3.676,-11.4667,0.9999979090043
# +units=m +no_defs
# ---- To Coordinate System ----
#       Cyl, Sph&Ell
# +proj=tmerc +lat_0=0 +lon_0=16.5 +k_0=0.9999 +x_0=500000 +ellps=WGS84
# +units=m +no_defs
5549500.250000 5060999.750000
432679.49       5061680.25 0.00
When i try to set any other +towgs84 params, the result is the same:
+ellps=bessel +towgs84=1,1,1,1,1,1,1 +units=m +no_defs +to +proj=tmerc
+lat_0=0 +lon_0=16.5 +k_0=0.9999 +x_0=500000 +ellps=WGS84 +units=m
+no_defs -v# ---- From Coordinate System ----
#       Cyl, Sph&Ell
# +towgs84=1,1,1,1,1,1,1
# +units=m +no_defs
#       Cyl, Sph&Ell
# +units=m +no_defs
I'm using proj.4 4.7.1, and i've tried using 4.6.1, with the same
results. Am i doing something wrong?
