[Proj] problems with m.proj (grass)
Massimo Di Stefano massimodisasha at yahoo.it
Tue Aug 3 05:00:49 PDT 2010
Hello All,
i'm using a fresh virtual machine where i installed gdal+grass6.5 from svn
trying to run the command m.proj on a text file "lonlatfile" ,  like :
-103.749769548 44.4373443836
i have :
(Tue Aug  3 11:12:35 2010)
m.proj -i input=/home/planetsasha/Desktop/PlanetSasha/lonlatfile
input parameters=[+proj=longlat +datum=WGS84]
output parameters=[ '+proj=utm' '+zone=13' '+a=6378206.4' '+rf=294.9786982' '+no_defs' '+nadgrids=/usr/local/src/gis/local/grass-6.5.svn/etc/nad/conus' '+to_meter=1.0']
Rel. 4.7.1, 23 September 2009
<cs2cs>:
Sys errno: 2: <system mess. texts unavail.>
'+proj=utm'
<cs2cs>:
'+zone=13'
<cs2cs>:
'+a=6378206.4'
<cs2cs>:
'+rf=294.9786982'
<cs2cs>:
'+no_defs'
<cs2cs>:
nus'
<cs2cs>:
'+to_meter=1.0'
(Tue Aug  3 11:12:36 2010) Command finished (1 sec)
have you any clue on what i'm missing ?
maybe something goes wrong with proj shared data ?
thanks for any suggestion,
Massimo.
