[Proj] Conferting from WGS84 latlong to Transverse Mercator
Hanlie Pretorius hanlie.pretorius at gmail.com
Tue Aug 31 23:43:23 PDT 2010
I'm just a bit confused about the signs of my converted coordinates.
My latlong coordinates are in South Africa: 28.375E and 27.375S
I'm using pyproj to convert from latlong to a Transverse Meractor PCS
centred on 29 deg East:
import pyproj
pr_tm = pyproj.Proj('+proj=tmerc +lat_0=0 +lon_0=29 +k=1 +x_0=0 +y_0=0
+ellps=WGS84 +units=m +no_defs')
x_latlong = 28.375
y_latlong = -27.375
x_tm, y_tm = pr_tm(x_latlong, y_latlong)
print x_tm,y_tm
output:
-61827.9202408 -3029337.78594
My question is this: why is the x-coordinate in the TM PCS negative?
It is in the eastern hemisphere, so surely it should be positive? Or
am I missing something?
Thanks
Hanlie
