[Proj] Difference between +nadgrids=@null and +towgs84=0,0,0
Tue Feb 9 10:44:09 PST 2010
Aaron Friesen wrote:
> Everyone,
>>From the FAQ "Changing Ellipsoid / Why can't I convert from WGS84
> to Google Earch /Virtual Globe Mercator?" it says to add
> +nadgrids=@null to "trick proj.4 into applying no change to
> the lat/long values when going to WGS84".
> How is that different than +towgs84=0,0,0?
Aaron,
When you use +towgs84=0,0,0 PROJ.4 still converts from the source
ellipsoid to geocentric coordinates, applies the offset and then
transforms from geocentric coordinates to the wgs84 ellipsoid.  That is,
a +towgs84=0,0,0 results in simple conversion of ellipsoid via geocentric
coordinates which still applies a large offset when the ellipsoids are
quite different.
+nadgrids=@null tricks PROJ.4 into skipping all that.
Best regards,
