[Proj] Standard projection for Mediterranean basin
Luigi Ponti lponti at infinito.it
Sat Feb 13 09:28:57 PST 2010
Hello,
I use PROJ.4 via GRASS GIS, and I would like to know if anyone is aware
of a standard projection for mapping the whole Mediterranean basin. I
need to do raster-based statistics on the maps, so I guess what I am
looking for is an equal area projection.
What I have found on the Web is a GIS built by the Joint Research Center
(JRC http://www.jrc.ec.europa.eu/) that used Lambert Azimuthal Equal
Area (LAEA) for the Mediterranean:
http://re.jrc.ec.europa.eu/pvgis/info/faq.htm#projection
However, it adopted the same projection center for both Europe and the
Mediterranean (0 °E and 48 °N). Is this correct?
There is also a workshop report
http://www.ec-gis.org/sdi/publist/pdfs/annoni-etal2003eur.pdf
that recommended LAEA with projection center 9 °E and 53 °N to be used
for statistical mapping in the European Union.
Based on this background it seems like LAEA would be fine. However, I am
unsure if there is a standard projection center and datum.
Thank you for any hints. Kind regards,
Luigi
