[Proj] Standard projection for Mediterranean basin
Luigi Ponti lponti at infinito.it
Mon Feb 15 10:23:09 PST 2010
Hello,
Just dropping a line to thank you all: your support on this topic
definitely exceeded my wildest expectations.
Kind regards,
Luigi
On 15/02/2010 18:31, Jan Hartmann wrote:
> Could you explain the relationship between Authalic Latitude and Equal
> Area projections? There is an article by John Snyder at
> http://www.jstor.org/stable/2562645?seq=1, but it's a bit above my
> mathematical head.
> Jan
> On 15-2-2010 18:01, Clifford J Mugnier wrote:
>> So?
>> Keep the parameters and just use Authalic Latitude.
>> Easy.
>> Clifford J. Mugnier, C.P., C.M.S.
>> Past National Director (2006-2008),
>> Photogrammetric Applications Division
>> American Society for Photogrammetry and Remote Sensing
>> and
>> Chief of Geodesy,
>> Center for GeoInformatics
>> Department of Civil Engineering
>> Patrick F. Taylor Hall 3223A
>> *LOUISIANA STATE UNIVERSITY*
>> Baton Rouge, LA  70803
>> Voice and Facsimile:  (225) 578-8536 [Academic]
>> Voice and Facsimile:  (225) 578-8925 [Research]
>> Honorary Life Member of the
>> Louisiana Society of Professional Surveyors
>> Member Emeritus of the ASPRS
>> Member of the Americas Petroleum Survey Group
>> http://www.asprs.org/resources/GRIDS/
>> <https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/exchweb/bin/redir.asp?URL=https://email.lsu.edu/%0Aexchweb/bin/redir.asp?URL=https://email.lsu.edu/%20exchweb/bin/redir.asp?URL=https://email.l>
>> *From:* proj-bounces at lists.maptools.org on behalf of Gerald I. Evenden
>> *Sent:* Mon 15-Feb-10 08:30
>> *To:* PROJ.4 and general Projections Discussions
>> *Subject:* Re: [Proj] Standard projection for Mediterranean basin
>> On Sunday 14 February 2010 11:46:30 pm Clifford J Mugnier wrote:
>> > From 1925 to 1946, there was a "British Grid" used by the Allied
>> Forces in
>> > the Mediterranean.  The British Army (GSGS) established the
>> "Mediterranean
>> > Zone" for the secant Lambert Conical Orthomorphic Projection where the
>> > central meridian was 29° East of Greenwich, and the latitude of
>> origin was
>> > 39° 30' N, the scale factor at origin was 0.99906, the False
>> Easting was
>> > 900 km, and the False Northing was 600 km.
>> > See my column in PE&RS for December of 2002 on Greece.
>> I had the inference that the request was for an equal-area
>> projection---a mode
>> that I consider preferable for thematic purposes.
>> The whole religious complexion of the modern world is due
>> to the absence from Jerusalem of a lunatic asylum.
>> -- Havelock Ellis (1859-1939) British psychologist
