[Proj] Portuguese Modified Grid - Datum 73
Clifford J Mugnier cjmce at lsu.edu
Tue Feb 16 10:27:31 PST 2010
Bravo, Professor Gonçalves!
Clifford J. Mugnier,
LOUISIANA STATE UNIVERSITY
From: proj-bounces at lists.maptools.org on behalf of Jose Gonçalves
Sent: Tue 16-Feb-10 11:34
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Portuguese Modified Grid - Datum 73
Hello
The proj string you refer is not correct. What is called in the EPSG
database "Portuguese Modified Grid - Datum 73" (epsg code 27492) is
the projection used in Portugal for the local datum called Datum 73.
Datum 73 was established in 1973 and is based on the Hayford
ellipsoid.
The correct definition of the projection can be found in the epsg file
distributed with proj:
# Datum 73 / Modified Portuguese Grid (deprecated)
<27492> +proj=tmerc +lat_0=39d00' +lon_0=-8.131906111111112 +k=1
+x_0=180.598 +y_0=-86.98999999999999 +ellps=intl +units=m +no_defs  <>
It is a Transverse Mercator projection with central point:
    lat_0=39d00'00.000"N
    lon_0= 8d07'54.862"W
No scale factor in central meridian is applied (+k_0=1)
It has a small false easting/northing
    x_0=180.598
    y_0=-86.990
This coordinate system was replaced by a new projection based on datum
ETRS89. The new projection, that the Portuguese Geographic Institute
(IGP) called PT-TM06, has a different central point. It's correct
definition is:
# ETRS89 / Portugal TM06
<3763> +proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334
+k=1 +x_0=0 +y_0=0 +ellps=GRS80 +units=m +no_defs  <>
In your proj string you had this central point mixed with the Datum 73
projection.
For a test point you can use the following (a geodetic point called Cabreira):
D73 Geographic - epsg:4274     (8d02'39.1243"W 41d38'17.2443"N)
D73 projected  - epsg:27492    (7488.375 218847.838)
ETRS89 Geographic - epsg:4258  (8d02'35.8302"W 41d38'20.2812"N)
ETRS89 Projected  - epsg:3763  (7483.752 218845.648)
To convert from Datum 73 to ETRS89 a Bursa-Wolf transformation can be
used. Using program cs2cs you can have, for example:
cs2cs +init=epsg:27492
+towgs84=-230.994,102.591,25.199,0.633,-0.239,0.900,1.950 +to
+init=epsg:4258 +towgs84=0,0,0
These parameters are given by IGP
(http://www.igeo.pt/produtos/Geodesia/Inf_tecnica/parametros_transformacao/parametros_Portugal.htm).
I have created NTv2 grid files to convert from datum 73 (and other
older national systems) to ETRS89 with better accuracy. They are
available in my page: http://www.fc.up.pt/pessoas/jagoncal/coordenadas
(sorry, only in Portuguese).
Regards
José A. Gonçalves
University of Porto, Portugal
2010/2/16 Roger Oberholtzer <roger at opq.se>:
> On Tue, 2010-02-16 at 14:53 +0100, OvV_HN wrote:
>> Dunno, but doesn't the utm projection uses a couple of preset values for
>> lat_0, k_0, x_0, y_0, and a calculated value of lon_0?
>> The tmerc projection seems more appropriate.
> You are surely correct. I will give this on a shot:
> +proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334 +k=1 +x_0=180.598 +y_0=86.990 +ellps=intl +units=m +no_defs
> Too bad it is always so hard to get appropriate test data for
> verification.
> Roger Oberholtzer
> OPQ Systems / Ramböll RST
> Ramböll Sverige AB
> Krukmakargatan 21
> P.O. Box 17009
> SE-104 62 Stockholm, Sweden
> Office: Int +46 10-615 60 20
> Mobile: Int +46 70-815 1696
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100216/30f01034/attachment.html>
