[Proj] Optimal Albers Standard parallels
strebe strebe at aol.com
Sat Feb 20 12:26:23 PST 2010
Oscar:
Presumably "LAEA" = Lambert azimuthal equal-area projection, in which case it has no standard parallels. The question would be where to center it. That's an easier problem to solve in the typical case than Albers; you simply find the small circle that circumscribes the area of interest. That small circle's center coincides with the center of the optimal Lamber azimuthal equal-area for the region.
Regards,
— daan Strebe
On Feb 20, 2010, at 8:09:00 AM, OvV_HN <ovv at hetnet.nl> wrote:
Noteworthy is the article:
An equal area projection for statistical mapping in the EU, Lysandros
Tsoulos.
To be found in the collection:
Map projections for Europe, Institute for Environment and Sustainability,
2001.
See page 50 f.f.
The author proposes a map projection for the whole of Europe with reasonably
low distortions.
Albers and LAEA are considered. The distortions at the boundaries of the EU
are lower with a LAEA than with an Albers projection.
http://www.ec-gis.org/document.cfm?id=425&db=document
http://www.ec-gis.org/sdi/publist/pdfs/annoni-etal2003eur.pdf
By the way, do you have a similar algorithm for optimal parallels for the
LAEA projection?
Oscar van Vlijmen
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100220/aae46ef0/attachment.html>
