[Proj] Trouble integrating Proj4 into application
nicolas david ericnico.david at gmail.com
Mon Jun 14 12:17:22 PDT 2010
Hi
I've done quite same thing recently ( debian and ubuntu) and don't have any
specific problems.
a) you have to take care when including proj4 files, because it's an ANSI C
library and not a C++ lib. So, within a C++ project you have to use
proj_api.h.
b) Concerning ENV variable. I know two of them and one is needed in order to
find data file.
PROJ_LIB : path to your proj data file ( nad, epsg etc..)
PROJ_DEBUG : if set to 1 make proj4 more verbose.
Hope it's helpful.
Nicolas David
2010/6/14 James Kilroy <jt_kilroy at yahoo.com>
>  Hello All,
> My name is James Kilroy and I am a brand new user of Proj4.  I have an
> extensive GIS back ground so I have a good grasp of the concepts, and I have
> been coding professionally (C/C++) for over 20 years.  I have installed the
> code base for Proj4 on my Linux server (Fedora, very recent build).  The
> build went without a hitch, all programs test out fine.  My problem is I
> can't get the lib to compile into my project.  Keeps giving me lib not found
> errors, though the lib is built, in place, and has proper permissions.  Are
> there any specific compiler directives required or ENV variables that are
> needed that I am not aware of?
> Thanks,
>  James Kilroy
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100614/1931fb3d/attachment.html>
