[Proj] +axis switch to control axis orientation
Daniel Morissette dmorissette at mapgears.com
Tue Mar 2 11:54:13 PST 2010
Frank Warmerdam wrote:
> If I just carry through the EPSG axis orientation, I'm worried that
> lots of coordinate systems that were in reasonably wide use will
> suddenly be broken.  I am not sure how to address this.  I could take
> the EPSG/EPSGA approach where I only used the EPSG axis orientation
> in exceptional circumstances (like TM south oriented projections) in
> the epsg init file, but do use them all the time in the "epsga" file.
I see your point, I had not thought of those potential side-effects.
Perhaps the EPSG/EPSGA approach would be best then, and apps that want
to use +axis info would read it from the EPSGA file.
Daniel Morissette
http://www.mapgears.com/
