[Proj] Region Finder
` ` teletautala at hotmail.com
Fri Mar 12 13:41:19 PST 2010
Thank you for your post.  I will look into geos.
-Daniel
> Date: Thu, 11 Mar 2010 18:51:58 -0500
> From: warmerdam at pobox.com
> To: proj at lists.maptools.org
> Subject: Re: [Proj] Region Finder
> ` ` wrote:
> > I have a the latitude/longitudes for a school boundary and I want to
> > know if an address is in that boundary.  Is there a way to find out if a
> > coordinate is within a latitude/longitude boundary?  Or even better
> > would be to use an address and find out what boundary it is in.
> Daniel,
> There are two parts to your question, neither of which have to do with
> PROJ.4:
> 1) The ability to determine the lat/long location associated with an
> address (ie. a postal address).  This is called geocoding.   The following
> posts by Martin Davis should provide a bit of background on geocoders.
> http://lin-ear-th-inking.blogspot.com/2010/03/open-source-geocoders.html
> http://lin-ear-th-inking.blogspot.com/2010/03/more-open-source-geocoders.html
> 2) The ability to determine if a point is within a polygon or conversely
> which polygon within a set the point is in.  This is a geometry operation.
> One of the best known geometry libraries is GEOS (a C++ port of JTS which
> oddly is also Martin Davis' project).
>    http://geos.osgeo.org/
> Good luck,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
_________________________________________________________________
Hotmail: Trusted email with powerful SPAM protection.
http://clk.atdmt.com/GBL/go/210850553/direct/01/
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100312/d5db6f03/attachment.html>
