[Proj] Problem with inverse stereo projection
massimo costantini massimo.costantini at gmail.com
Fri May 14 01:51:44 PDT 2010
someone can tell me why if I set a center o stereo projection on lat 0.0 and
lon 0.0 the inverse projection (stereo to geo), return always 0E 0N.
Thank you
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100514/5a489049/attachment.html>
