[Proj] Belgian 2008 Coordinates
Irwin Scollar al001 at uni-koeln.de
Sun Sep 12 10:32:37 PDT 2010
I need to use EPSG 3812 to read and write GeoTiffs using code from
LibGeoTiff 1.3.0, and although the parameters are in the
coordinate_reference_system.csv file, I can't open a GeoTiff file
with these parameters correctly and receive an "unkown 3812" error in
the geotifcp output.
The proj4 entry in the EPSG Spatial Reference is empty, but the Human
Readable OGC WKT entry correctly shows:
PROJCS["ETRS89 / Belgian Lambert 2008",
     GEOGCS["ETRS89",
         DATUM["European Terrestrial Reference System 1989",
             SPHEROID["GRS 1980",6378137.0,298.257222101,
                 AUTHORITY["EPSG","7019"]],
             TOWGS84[0.0,0.0,0.0,0.0,0.0,0.0,0.0],
             AUTHORITY["EPSG","6258"]],
         PRIMEM["Greenwich",0.0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.017453292519943295],
         AXIS["Geodetic latitude",NORTH],
         AXIS["Geodetic longitude",EAST],
         AUTHORITY["EPSG","4258"]],
     PROJECTION["Lambert Conic Conformal (2SP)",
         AUTHORITY["EPSG","9802"]],
     PARAMETER["central_meridian",4.359215833333335],
     PARAMETER["latitude_of_origin",50.79781500000001],
     PARAMETER["standard_parallel_1",49.833333333333336],
     PARAMETER["false_easting",649328.0],
     PARAMETER["false_northing",665262.0],
     PARAMETER["standard_parallel_2",51.16666666666667],
     UNIT["m",1.0],
     AXIS["Easting",EAST],
     AXIS["Northing",NORTH],
     AUTHORITY["EPSG","3812"]]
Can this be patched in libgeotif?  If so, where should the patch(es)
be made, and what should be the correct entry in epsg_pcs.inc ?
I tried
/* Newer PCS */
ValuePair(PCS_ETRS89_Belgium_Lambert_2008, 3812)
without success.
Irwin Scollar
