[Proj] ED50_UTM to ED50_TM (Not sure!)
Hamed Amini hamed.amini at hotmail.co.uk
Mon Sep 20 03:04:25 PDT 2010
Hi there,
I'd like to perform a transformation using cs2cs as a beginner. Can you
please if I can do the following conversion using proj, and if so, what
command should I use?
Thanks,
Hamed
FROM
GEODETIC DATUM AS SURVEY  ED50        INTERNATIONA 6378388.000 297.0000000
DATUM SHIFT ED50 TO WGS84  -89.5 -93.8-123.1 0.000 0.000-0.156 1.2000000
GEODETIC DATUM POSTPROC.  ED50        INTERNATIONA 6378388.000 297.0000000
DATUM SHIFTS                 0.0   0.0   0.0 0.000 0.000 0.000 0.0000000
VERTICAL DATUM            ES                      ECHO SOUNDER POSITION
PROJECTION                001 U.T.M. NORTHERN HEMISHPERE
ZONE                      31 N
GRID UNITS                1 INTERNATIONAL METERS    1.000000000000
HEIGHT UNITS              1 INTERNATIONAL METERS    1.000000000000
ANGULAR UNITS             1 DEGREES
TO
GEODETIC DATUM (SURVEY)    ED50-UK     HAYFORD INT  6378388.000 297.0000000
1ED-50 TO WGS 84             -89.5 -93.8-123.1 0.000 0.000-0.156 1.2000000
GEODETIC DATUM (POST PLOT) ED50-UK     HAYFORD INT  6378388.000 297.0000000
DATUM SHIFT H1400-H1500       0.0   0.0   0.0 0.000 0.000 0.000 0.0000000
VERTICAL DATUM             SL  : ECHOSOUNDER
0PROJECTION                 003 TM NORTH
0GRID UNITS                 1INTERNATIONAL METRES     1.000000000000
HEIGHT UNITS               1INTERNATIONAL METRES     1.000000000000
ANGULAR UNIT               1DEGREES
CENTRAL MERIDIAN           0000000.000E
GRID ORIGIN                0000000.000N0000000.000E
GRID COORD. AT ORIGIN        500000.00E 0000000.00N
SCALE FACTOR               0.9996000000
LAT/LON WHERE SCALE DEF    0000000.000N0000000.000E
CENTRAL MERIDIAN            3 0 0.000E
-----------------------------------------------------------------------------EOF
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ED50-UTM-to-ED50-TM-Not-sure-tp5549777p5549777.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
