[Proj] Dutch correction grid
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Apr 7 01:14:04 PDT 2011
If someone could give me some pointers to the grid shift format and the
way it is used in PROJ, I will have a go at producing a grid shift file
from this spreadsheet. Where did you get it from, Bart?
Jan
On 7-4-2011 9:18, Bart van den Eijnden (OSGIS) wrote:
> Hi,
> did anybody ever attempt to transform the information from the Dutch
> correction grid into a format for a datum shift grid file that PROJ.4 can
> read?
> http://www.rdnap.nl/images/Landelijk%20correctiegrid%20nieuwe%20NAP-publicatie_tcm174-280038.xls
> Best regards,
> Bart
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
