[Proj] Which Coordinate system/Projection should i assign to shapefile ?
Mustafa646 noorcs22 at gmail.com
Mon Apr 18 01:50:37 PDT 2011
hello all,
I digitize a tiff image file in Map Window. I assign three Lat-lon points
based on wgs84 to this tiff image before digitizing. The sample points are
(59.350067,18.208219), These are lat-lon points of Lidingö Area in sweden.
After completing the digitizing, i get to know that there is no projection
defined to my newly generated shapefile. Then i assign following projection
to shapefile by using Map Window GIS tools-> assign projection to
shapefiles.
Category: Geographic Coordinate System
Group: World
WGS 1984 (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs )
Actually i want to display this shapefile over Google map, but when i tried
to display it over Google map, it displayed on wrong place in ocean
somewhere, So, where i am wrong ? How can i fix it ? Please give some useful
suggestion.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Which-Coordinate-system-Projection-should-i-assign-to-shapefile-tp6282842p6282842.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
