[Proj] Offset when converting coordinates from ESRI:31700 to EPSG:4326
Adrian Popa adrian_gh.popa at romtelecom.ro
Fri Apr 22 01:57:54 PDT 2011
Hello everyone,
I have a problem when converting coordinates from ESRI:31700 (Stereo 70)
to WGS84 (EPSG:4326). The coordinates I get from the conversion have an
offset from the original coordinate of about 50m. Here's an example:
Original coordinates (Stereo 70):  587486.770, 326878.452
Converted coordinates (WGS84): 26.099032,44.436575
Real coordinates (converted from Stereo 70 with Global Mapper and
checked with a GPS unit): 26.097414, 44.436335
For the conversion I'm using cs2cs Rel. 4.7.1, 23 September 2009 on
Ubuntu 10.04.
My ESRI/EPSG definitions are as follows:
EPSG:
# Dealul Piscului 1970/ Stereo 70 (deprecated)
<31700> +proj=sterea +lat_0=46 +lon_0=25 +k=0.99975 +x_0=500000
+y_0=500000 +ellps=krass +units=m +no_defs <>
# WGS 84
<4326> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs <>
ESRI:
<31700> +proj=stere +lat_0=46 +lon_0=25 +k=0.999750 +x_0=500000
+y_0=500000 +ellps=krass +units=m +no_defs  no_defs <>
The command line I'm using is:
$ echo 587486.770 326878.452 | cs2cs +init=esri:31700 +to
+init=epsg:4326 -f '%0.6f'
26.099032    44.436575 0.000000
$ echo 587486.770 326878.452 | cs2cs +init=epsg:31700 +to
26.098934    44.436629 0.000000
I've read that there is a small difference between stere and sterea
projections, and sterea should give a better approximation, but I've
tried with both projections and I still get the ~50m offset.
Can anybody clue me in as to what I'm doing wrong? I must be missing
something, but I don't know what (I'm somewhat of a noob when it comes
to map projections).
P.S. The definition for Stereo 70 that I received with my data looks
consistent with the definition inside proj4:
PROJCS["Stereo_70",GEOGCS["GCS_Dealul_Piscului_1970",DATUM["D_Dealul_Piscului_1970",SPHEROID["Krasovsky_1940",6378245,298.3]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Double_Stereographic"],PARAMETER["False_Easting",500000],PARAMETER["False_Northing",500000],PARAMETER["Longitude_Of_Origin",25],PARAMETER["Scale_Factor",0.99975],PARAMETER["Latitude_Of_Origin",46],UNIT["Meter",1]]
Thanks,
Adrian
Acest mesaj si orice fisiere sau documente atasate contin informatii confidentiale, clasificate conform regulilor interne ROMTELECOM. Mesajul este destinat doar persoanei sau entitatii adresate si altora autorizati sa-l primeasca. Daca dvs. nu sunteti in aceasta situatie, prin aceasta va informam ca orice dezvaluire, copiere, distribuire sau orice alta actiune bazata pe continutul acestor informatii este strict interzisa si pot fi aplicate sanctiuni, potrivit legii. Daca ati primit acest mesaj din greseala, va rugam sa ne informati imediat si sa stergeti mesajul din sistemul dvs. De asemenea, va rugam sa tineti cont ca transmisia nu poate fi garantata ca fiind sigura sau fara erori. Va multumim!
