[Proj] Projection advice
Roger Oberholtzer roger at opq.se
Thu Dec 8 03:37:11 PST 2011
I have a system that starts with WGS84 lat/long, projects them so as to
obtain northings/eastings, does some fiddling with the locations, and
then converts them back in to WGS84 lat/long. The conversion from/to
lat/long is done by proj. The fiddling with the northings/eastings is
done based on some INS that provides relative movement information in
meters. Only the WGS84 lat/longs are kept.
Currently, I use a projection for the local region. The thought was that
this would best 'match' the INS movements, which are of course always
local. I would like to generalize this solution by perhaps not using a
local projection. Instead use a generic projection everywhere. It seems
reasonable to do this as (1) the projection will not be kept, and (2)
the movements applied to the projections are relative.
My question is; is there a 'best' projection to use for such a
procedure?
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
