[Proj] Vertical Datum Shift
Daniel Komisar dkomisar at mak.com
Wed Dec 14 08:27:27 PST 2011
I'm having trouble figuring out how to the the +geoidgrids option. I'm trying to
convert EGM96 values to WGS84 with cs2cs (I will eventually be converting a dted
file but first I'm trying to just get this to work) and I cannot get it to alter
the values so I'm doing something wrong. Using 4.7.1.
cs2cs +proj=latlong +ellps=WGS84 +datum=WGS84 +geoidgrids=egm96_15.gtx +to
It always outputs the exact same numbers I put in.
Thanks.
