[Proj] Geos projection with flipped axis
Martin Raspaud martin.raspaud at smhi.se
Tue Dec 20 01:30:15 PST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
I'm having a discussion with someone working on the GOES-R satellite,
and the differences with the Meteosat series satellites.
The native projection of the image captured by the Meteosat satellite is
described in the CGMS'03 and is implemented in proj.4 as the "geos"
projection. Looking at the details, the Meteosat imager rotates first in
the horizontal plane then rotates up or down. The GOES-R satellite
however rotates first in the vertical plane and then rotates east or west.
Now, the two projection are very similar I think, it's just a matter of
swapping two axis. However, it looks like the +axis parameter is not
implemented in the geos projection.
Am I mistaken ? Or would it be possible to implement +axis for geos ? Or
is there another way to do what I describe using the geos projection ?
Best regards,
Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (GNU/Linux)
Comment: Using GnuPG with Red Hat - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJO8FWnAAoJEBdvyODiyJI4GRYH/2pWwXgwfRSFmb/iZLJeu1tc
eYRHGrHYHavpn1vc4gPryy3ZQL0ywjobSfucIUeap7hi83eaIUqxZjD8YTGtMbHd
lbAdtauDNhNakc1isv+zXj89Vf+DEV3CYMFliW504KP0ONNkHSFcajk7ZTDa5eec
YaOoyImUiKmhsoU7zMWkwCJmNKFUWAgYPWAo2f14qMVDDngeXHMvZGDq6421DYzV
MtO95wCm6G67FEmn5C7sO0CFOAe1eAEiWiqWeUpXtyUO9k7tzn24+GEyhFY2FbC0
hIOcM8DmoGTAY56OZ80xLQHgN333xC7GkFsZQYORRC9knC3PBcwKtHG/HgDCXhM=
=Ru94
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111220/71b35ca4/attachment.vcf>
