[Proj] Build fails on Windows
Michael Speth SpethM at landcareresearch.co.nz
Wed Dec 21 18:46:45 PST 2011
Greetings,
  I am away from the office today, but I'll look into this first thing tomorrow morning.  I did not test building in windows, only on a 64-bit Ubuntu system.
Thanks
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On Behalf Of J. Luis [jmfluis at gmail.com]
Sent: Thursday, 22 December 2011 2:49 p.m.
To: proj at lists.maptools.org
Subject: [Proj] Build fails on Windows
On Windows (VS2010) the build errors after the addition of the the
healpix projection
Joaquim Luis
PJ_healpix.c(149) : error C2057: expected constant expression
PJ_healpix.c(149) : error C2466: cannot allocate an array of constant size 0
PJ_healpix.c(149) : error C2087: 'vert' : missing subscript
PJ_healpix.c(222) : warning C4048: different array subscripts : 'double
(*)[1]' and 'double [18][18]'
PJ_healpix.c(238) : warning C4048: different array subscripts : 'double
(*)[1]' and 'double [12][12]'
PJ_healpix.c(572) : error C2143: syntax error : missing ';' before 'type'
PJ_healpix.c(573) : error C2143: syntax error : missing ';' before 'type'
PJ_healpix.c(575) : error C2065: 'x' : undeclared identifier
PJ_healpix.c(575) : error C2065: 'y' : undeclared identifier
PJ_healpix.c(588) : error C2061: syntax error : identifier
's_healpix_inverse'
PJ_healpix.c(588) : error C2059: syntax error : ';'
PJ_healpix.c(588) : error C2059: syntax error : 'type'
PJ_healpix.c(652) : error C2065: 's_healpix_inverse' : undeclared identifier
I also get this warnings that are independent of the above problem
pj_open_lib.c(46) : warning C4129: 'p' : unrecognized character escape
sequence
pj_open_lib.c(46) : warning C4129: 'c' : unrecognized character escape
sequence
sequence
sequence
pj_open_lib.c(46) : warning C4129: 'V' : unrecognized character escape
sequence
pj_open_lib.c(46) : warning C4129: 'S' : unrecognized character escape
sequence
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Please consider the environment before printing this email
Warning:  This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
