[Proj] Build fails on Windows
Michael Speth spethm at landcareresearch.co.nz
Thu Dec 22 14:53:12 PST 2011
That clears things up for me.  I'll work on making HEALPix & rHEALPix
C89 compliant.  Thank you for the help!  I'll post a patch once its
completed ... hopefully before x-mass.
Regards
On 23/12/11 11:00, Frank Warmerdam wrote:
> On Thu, Dec 22, 2011 at 1:10 PM, Michael Speth
> <spethm at landcareresearch.co.nz>  wrote:
>> Hello,
>>    Why is proj.4 being compiled with a C++ compiler?  Variable length
>> arrays are valid C language constructs but are not in C++.  So does
>> proj.4 need to be both C and C++ compiler compliant?
> Michael,
> This will need to be corrected before we release.  I endevour
> to have PROJ.4 and related projects compilable with a wide
> variety of compilers.  If you are willing to do it, great.  If not
> I'll try and/or disable healpix.
> With libtiff 4 released, and GDAL 1.9 close to release I might
> just make a real push to get PROJ.4 4.9.0 out over the holidays.
> Best regards,
Michael Speth
Research Systems Developer
Landcare Research
