[Proj] Little geod problem
Karney, Charles charles.karney at sri.com
Fri Feb 25 07:38:10 PST 2011
I recommend the version of Geod that is included with GeographicLib,
  http://geographiclib.sf.net
Here's what it gives for this problem:
echo -12.4989444 130.88649687 -12.4989444 130.8864967 | Geod -i
-90.00000002 -89.99999998 0.018 0.018
The man page is available at
  http://geographiclib.sf.net/html/Geod.1.html
  --Charles
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On Behalf Of Mikhail Tchernychev [misha at mail.geometrics.com]
Sent: Thursday, January 20, 2011 14:21
To: proj at lists.maptools.org
Subject: [Proj] Little geod problem
  Hello list,
I came across a small inconsistency in the geod program. What I use is:
geod +ellps=WGS84  -I -f "%.3lf" data_file
With data file:
What I got is:
-1.#IO  -1.#IO  -1.#IO
These two points are very close to each other however are not identical.
I would
not be surprised if geod would return 0 0 0. If fact this is what it
does if points
are simply identical.  I would suggest to round result to 0, even if it
is not but say
smaller than some reasonable number (0.01 m?)
  I hope this would help to improve great proj software even more.
Thank you,
Mikhail
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
