[Proj] Lat/long to utm easting error
Noel Zinn (cc) ndzinn at comcast.net
Wed Jan 5 17:52:56 PST 2011
Adam,
What you're expecting works only on the Central Meridian (CM) and not
elsewhere due to convergence of the meridians.
Google "convergence of the meridians" for a fuller explanation.
Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
-----Original Message-----
Sent: Wednesday, January 05, 2011 6:18 PM
To: proj at lists.maptools.org
Subject: [Proj] Lat/long to utm easting error
I have run into something that I don't understand, and I hope someone can
help explain.
I was doing some conversions of points, and ran into a problem.  I finally
narrowed it down to the following:
If I take two points, at the identical longitude, with a small change in
latitude, and convert them each to UTM, I would expect nearly identical
easting values.  But I am not seeing that.  For example:
cs2cs +proj=latlong +datum=WGS84 +to +proj=utm +datum=WGS84 +zone=17 -r
42d37'3.77503"N 83d59'35"W
254524.57 4722707.58 0.00
42d37'0.02186"N 83d59'35"W
254520.47 4722591.80 0.00
Above there is  ~4 m easting difference, with just a small (~120m) change in
latitude.  Since these points are exactly North-south of each other,
shouldn't they have the same easting, at least when they are this close to
each other in latitude?
Thanks much for any explanations,
--Adam
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
