[Proj] [mapserver-users] Projection problems
Mikael Rittri Mikael.Rittri at carmenta.com
Wed Jan 12 07:40:18 PST 2011
PS:
The trunk version of proj/nad/epsg, at
http://svn.osgeo.org/metacrs/proj/trunk/proj/nad/epsg
does seem to be based on the libgeotiff trunk. The entry for
epsg:28992 (Amersfoort / RD New) has a correct +towgs84 parameter.
I am not sure if you can use Proj version 4.7.0 and just
replace its proj/nad/epsg file by the trunk version,
since the trunk version might contain some new projection
types.  But it could be worth a try.
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Mikael Rittri
Sent: Monday, January 10, 2011 11:16 AM
To: PROJ.4 and general Projections Discussions
Cc: Milo van der Linden
Subject: Re: [Proj] [mapserver-users] Projection problems
Hello Jan,
Frank has recently done great improvements in the generation of a preferred datum shift for each datum in the EPSG database.
This is a more cumbersome task than one might think (trust me!).
His improvements are visible in the trunk for libgeotiff,
   http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv
but are not included in the latest released version, libgeotiff 1.3.0 from May 2010.
I expect the improvements will eventually make it to Proj, I would guess version 4.8.0, but I don't know when that is planned.  Nor do I know if there is preliminary Proj/epsg file available that has been generated from the libgeotiff trunk.
Regards,
Mikael Rittri
Carmenta AB
Sweden
www.carmenta.com
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Jan Hartmann
Sent: Friday, January 07, 2011 3:50 PM
To: Milo van der Linden
Cc: proj at lists.maptools.org; mapserver-users at lists.osgeo.org; basvmrs
[-- text deleted, see http://lists.maptools.org/pipermail/proj/2011-January/005504.html --] _______________________________________________
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
