[Proj] Geotrans, PCTrans and cs2cs - different angle signs?
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 17 23:59:39 PST 2011
Yes, the angles can be given either in "right-hand" (American) or
"left-hand" (European) convention. See the thread on:
http://lists.maptools.org/pipermail/proj/2010-April/005198.html
Mind that angles can be given either in (micro)degrees (PROJ) or radians
(EPSG). You can find a discussion about the conversion from EPSG numbers
to PROJ, with both sign and radians conversion in:
http://trac.osgeo.org/geotiff/ticket/22
with an attached spreadsheet to perform the computation for the Dutch
coordinate system (EPSG:28992)
Jan
On 01/18/11 06:24, Mikhail Tchernychev wrote:
> Hello List,
> It came to my attention that 7-parameters values should be different for
> cs2cs and
> programs like Geotrans  and PCTrans. It seems all 3 angles should have
> different
> sign to match cs2cs results. Shifts stay the same, as well as scaling
> (well, for
> geotrans it is not in ppm).  I wonder if it is something well known or
> am I missing
> something?
> Thank you,
> Mikhail
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110118/0a6df9d0/attachment.html>
