[Proj] "Reverse" graticule for the transverse Mercator projection
Charles Karney charles.karney at sri.com
Tue Jul 26 08:14:59 PDT 2011
Projections are often visualized by plotting graticules, lines of
constant latitude or longitude, in the projected space.  With tools such
as Google Earth that allow you to see the world in 3d, it makes sense to
display the *reverse* graticule for the projection, that is lines of
constant easting and northing on the 3d world.
For your amusement, download
   http://geographiclib.sourceforge.net/tm-graticule.kml
and load into Google Earth.  This shows the reverse graticule for
transverse Mercator for the WGS84 ellipsoid with a 1000 km spacing.  I
adjusted the scale so that the distance from the equator to the pole is
10000 km and chose the prime meridian for the central meridian.  The
projection is well behaved at the north and south poles.  The projection
has a branch cut on the equator near the "meta poles", namely for
longitude in [-97.36373, -82.63627] and in [82.63627, 97.36373].
Charles Karney <charles.karney at sri.com>
SRI International, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
