[Proj] wgs84 northings and eastings
Roger Oberholtzer roger at opq.se
Tue May 24 10:29:45 PDT 2011
So, perhaps I should re-phrase my original question:
I would like to project WGS84 latitude and longitudes on to a transverse
mercator surface, without any datum shift. How should that be specified
in proj? I use the C interface. Using ED50 as an example, I divide the
proj string into a 'from':
	from = pj_init_plus("+proj=latlong +datum=WGS84");
and a 'to':
	to = pj_init_plus("+proj=utm "
			"+ellps=intl "
			"+k=0.999600 "
			"+x_0=500000.0 "
			"+y_0=0.0 "
			"+zone=30 "
			"+units=m "
			"+towgs84=-125.098545,-76.000054,-156.198703,0.0,0.0,-1.129,8.30463103 "
			"+no_defs");
I then use pj_transform(from, to, ...) to do the transform. (Switching
the 'from' and 'to' allows a reverse transform).
Would this be correct for the transform?
	to = pj_init_plus("+proj=merc "
                		"+k=1.0 "
				"+x_0=0 "
				"+y_0=0 "
				"+lon_0=0.0 "
				"+lat_0=0.0 "
				"+towgs84=0,0,0,0,0,0,0 "
				"+a=6378137 "
				"+b=6378137 "
				"+no_defs");
It is the entire 'from', and the +towgs= in the 'to' that have me
confused. This is based on http://spatialreference.org/ref/sr-org/45/
All comments welcome!
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
