[Proj] esri shape files
strebe at aol.com strebe at aol.com
Thu May 26 16:54:02 PDT 2011
 The .prj file is in Well Known Text format (WTK) documented here:
     http://www.geoapi.org/2.0/javadoc/org/opengis/referencing/doc-files/WKT.html
Geocart (for example) requires the .prj file to be present, does inspect it, but requires its contents to declare the GEOG projection in order to make use of the Shapefile. Therefore at least one program trusts and “uses” the contents of the .prj file.
Geocart does not inspect the .sbn file.
Regards,
— daan Strebe
-----Original Message-----
To: proj at lists.maptools.org
Sent: Thu, May 26, 2011 2:50 pm
Subject: [Proj] esri shape files
Hello,
is there any document what should be put in the .prj or .sbn file
that should go with the esri shape files? and does any program
really trust or use what is in it?
This link seems to give some information
http://en.wikipedia.org/wiki/Shapefile#Shapefile_projection_format_.28.prj.29
but no too much.
regards: S.L.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110526/a3690d28/attachment.html>
