[Proj] Ortho Projection Question
Noel Zinn (cc) ndzinn at comcast.net
Thu Nov 3 21:53:15 PDT 2011
Brian,
If ESRI's PROJECTION["Local"] is also known as ESRI's "Local Cartesian",
then you'll need an ellipsoidal version of the orthographic projection to
match it.  I suspect that Proj.4's +proj=ortho is a spherical version of the
orthographic.
You make it difficult to test this by tossing in a transformation from NAD27
to WGS84 (+proj=longlat +datum=WGS84 +no_defs no_defs) with parameters
unknown to me.  Is this NADCON?  How about one problem at a time?  Can you
provide ESRI and Proj.4 lat/lon outputs in NAD27?
You can find the equations for the ellipsoidal orthographic here:
http://www.hydrometronics.com/downloads/Ellipsoidal%20Orthographic%20Projection.pdf
The inverse given in the link is iterative.  Charles Karney has provided a
closed inverse that has not yet been included in the linked paper.
Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
-----Original Message-----
Sent: Thursday, November 03, 2011 8:37 PM
To: Proj at lists.maptools.org
Subject: [Proj] Ortho Projection Question
I am trying to duplicate an ESRI "local" projection with Proj.4
parameters and can't quite get it worked out.  The ESRI custom
projection file has:
PROJCS["Twin_Creeks_Mine_Grid (Local)",
GEOGCS["GCS_North_American_1927",
DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],
PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
PROJECTION["Local"],
PARAMETER["False_Easting",14225.0],
PARAMETER["False_Northing",36603.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Azimuth",0.0],
PARAMETER["Longitude_Of_Center",-117.183175],
PARAMETER["Latitude_Of_Center",41.217358],
UNIT["Foot_US",0.3048006096012192]]
The equivalent Proj.4 parameters I've setup are:
+proj=ortho +datum=NAD27 +lat_0=41.217358 +lon_0=-117.183175
+x_0=14225.0 +y_0=36603.0 +units=us-ft no_defs
I want to convert to lat-long WGS84 so I am going to this:
My input test point is:
x = 15768.1900000000 y = 65384.1600000000
In ESRI land I get back (lat-long): 41.160175 -117.177571
With Proj.4 I am getting: 41.0674232619472 -117.296349865729
I've also tried this with a couple of specific +to_wgs transformations
on the ESRI and Proj.4 side and still cannot get the conversions to
match.
This is all with Proj.4 Rel. 4.7.1, 23 September 2009.
What I'm wondering about is the ortho "projection" and if there is
maybe a better option to use?  I've searched around the web a bit and
read about concerns with ortho so also not sure if there is a proj
update beyond 4.7.1 that might help?  I know this whole kind of
direct-Cartesian conversion isn't the best thing, but generally stuck
just trying to match what Arc is doing.
Thanks for the help, Brian.
Proj mailing list
http://lists.maptools.org/mailman/listinfo/proj
