[Proj] load arcSDE raw data from database and convert tolat/long
Noel Zinn (cc) ndzinn at comcast.net
Wed Nov 9 08:30:33 PST 2011
Vincenzo,
Here’s a radical suggestion for your consideration.  Approach the source of these coordinates and get projection, grid, ellipsoid and datum shift parameters.  Forensic sleuthing is great entertainment, but without definitive documentation it’s just an informed guess.
Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Wednesday, November 09, 2011 10:15 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] load arcSDE raw data from database and convert tolat/long
On 11/09/2011 04:50 PM, Clifford J Mugnier wrote:
  Vincenzo,
Dear Clifford,
  Since you did not mention where you are, I had to look up the coordinates to give you a clue.  Since your coordinates are near Rome, the local coordinate system is a Gauss-Boaga Transverse Mercator referenced to the Monte Mario Datum of 1940 on the International ellipsoid.  For further details, see my column on the Italian Republic in the August 2005 issue of Photogrammetric Engineering & Remote Sensing.  The pdf of that column may be downloaded from the society's website at www.ASPRS.org.
  Clifford J. Mugnier, C.P., C.M.S.
based on your advice i surfed the web and found:
http://www.rigacci.org/wiki/doku.php/tecnica/gps_cartografia_gis/gauss_boaga_wgs84
So i tried to use pyproj to do the computation:
In [50]: p = Proj(proj="tmerc", lat_0="0", lon_0="9", k="0.9996", x_0="1500000", y_0="0", ellps="intl", units="m", towgs84="-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68")
In [51]: x,y = p(45.463681, 9.1881714)
In [52]: print x,y
5790656.63279 1259107.51994
But it's still wrong, i should obtain something close to X=2159820 Y=1457635
Any other suggestion?
Thanks for all.
Vincenzo Ampolo
http://vincenzo-ampolo.net
http://goshawknest.wordpress.com
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111109/916c2c44/attachment.html>
