[Proj] Using jniwrap
Martin Desruisseaux martin.desruisseaux at geomatys.fr
Wed Nov 23 13:33:35 PST 2011
Le 23/11/11 22:13, Michael Speth a écrit :
> The proj command that I am using I think is taking coordinates from a unit
> sphere and projecting with the HEALPix projection (I am currently working on
> this projection and will provide a patch to Frank).  It doesn't read data from
> a file.
> So I would like to replicate this using the jniwrap for my own testing
> purposes.  Can this be done?
It should, I'm not sure to understand which issue you are facing... The code
posted in your previous email should work. Do you get an exception or unexpected
result?
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111123/25392abc/attachment.html>
