[Proj] Knowing projection from bounding box values.
Mustafa646 noorcs22 at gmail.com
Tue Sep 20 06:45:21 PDT 2011
If bounding box values are given, then can we determin the projection ?
let say i have following bounding box values:
Bounding Box (Min X, Max X) = 161691.814, 161835.595
Bounding Box (Min Y, Max Y) = 6581562.789, 6581647.802
then, what will be the projection file or EPSG code ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Knowing-projection-from-bounding-box-values-tp6812329p6812329.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
