[Proj] Knowing projection from bounding box values.
Clifford J Mugnier cjmce at lsu.edu
Tue Sep 20 07:52:06 PDT 2011
Looks like UTM, Southern Hemisphere, West of the Central Meridian of some Zone.  Which Zone is impossible to determine other than knowing what the context of the data represents as all 60 Southern Hemisphere Zones can have the same identical set of coordinates.  If you narrow the Zones down to where there's an area of interest, you have a good clue.
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3531
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Voice and Facsimile:  (225) 578-8536 [Academic]
Voice and Facsimile:  (225) 578-4578 [Research]
Cell: (225) 328-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of Mustafa646
Sent: Tue 20-Sep-11 08:45
To: proj at lists.maptools.org
Subject: [Proj] Knowing projection from bounding box values.
If bounding box values are given, then can we determin the projection ?
let say i have following bounding box values:
Bounding Box (Min X, Max X) = 161691.814, 161835.595
Bounding Box (Min Y, Max Y) = 6581562.789, 6581647.802
then, what will be the projection file or EPSG code ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Knowing-projection-from-bounding-box-values-tp6812329p6812329.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110920/e49cc059/attachment.html>
