[Proj] proj4 string for perfect sphere
support.mn at elisanet.fi support.mn at elisanet.fi
Tue Apr 17 02:54:11 PDT 2012
Hello,
Demitri Muna [thatsanicehatyouhave at me.com] kirjoitti:
> Hi Bob,
> Thanks very much for the extensive comments. The biggest thing I learned about GIS this week (starting from knowing nothing about it last week) is that calculations are primarily done on an XY plane which are projections of a curved surface. I had naively assumed going in that calculations and indices (e.g. spatialite) were optimized for the surface of a sphere.
A small notice for a beginner: If you want to stay accurate and avoid lots of trouble with projections generated errors never leave the sphere (or ellipsoid) just keep doing all calculations there - it is much easier (you don't need projections) and you will stay accurate for ever ;)
regards: Janne.
