[Proj] request help with Transverse_Mercator in proj
Rick Graves gravesricharde at yahoo.com
Sun Aug 12 18:41:57 PDT 2012
Hey,
Sorry to trouble you, but I still have a couple of states for which I need to get proj.4 working.  This time, it is Wisconsin.
I am starting with the Western most point in the state.  If you plug the following into maps.google.com, you will see it:
45.64120292600006, -92.88943290699996
I downloaded the shapefiles from the state web site.  In the shapefile, the minimum X point is this:
294822.7664999999, 578184.1052999999
Here is the metadata from the prj file:
PROJCS["NAD_1983_HARN_Wisconsin_TM",
GEOGCS["GCS_North_American_1983_HARN",
DATUM["D_North_American_1983_HARN",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",520000.0],
PARAMETER["False_Northing",-4480000.0],
PARAMETER["Central_Meridian",-90.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
I initialized proj as follows:
proj +proj=tmerc +lat_0=0.0 +lon_0=-90.0 +k=0.9996 +x_0=-4480000.0 +y_0=520000.0
When give proj this:
-92.88943290699996 45.64120292600006
I get this:
-4705175.18     5578245.14
But I am expecting this:
I assume I am not initializing proj correctly.
If someone could spot my mistake, I would appreciate it.
Thanks,
Rick Graves
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120812/61d17717/attachment.html>
