[Proj] a simple coordinate conversion problem
Mikael Rittri Mikael.Rittri at carmenta.com
Tue Aug 14 06:17:43 PDT 2012
Oscar, you wrote:
> I should say that about 5.4 km height difference and around 21 km
> difference in northerly direction (with respect to the WGS84
> ellipsoid) is quite significant.
> Possibly a bit too much to ignore, even for meteo applications.
Well, I could be wrong, but I think that meteorologists locate their
sensors, and thus the sensor data, by ordinary WGS84 long/lat (not
sure about the kind of height).  Then, what they say is roughly,
"Okay, let's all pretend that these long/lat (and height)
 values refer to a perfect sphere with radius = 6371 km."
Then, they can use spherical projections (like Web Mercator) and
do whatever computations they want on a sphere. Distances computed
on this sphere will vary by up to +/- 0.5 percent from true distances
on Earth, but I don't think they care.
The 21 km displacement you mention is what the meteorologists
would get if they their long/lat values really did refer to a
true sphere of radius 6371 km, georeferenced by GPS for example,
but I don't think that's what they do.
Reference: http://www.ie.unc.edu/cempd/projects/mims/spatial/grids_ellipsoids_map_proj.html
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of OvV_HN
Sent: Tuesday, August 14, 2012 2:04 PM
To: PROJ.4 and general Projections Discussions
Subject: [Proj] a simple coordinate conversion problem
In reply to:
Martin Ivanov martin.ivanov at ifg.uni-tuebingen.de
Fri Aug 10 07:48:32 EST 2012
Dear users of PROJ,
I have a data set on a perfect sphere with radius 6371 km. The "projection"
is latitude-longitude, so the data practically are unprojected.
I need to transform the coordinates of the points in my data set from the
sphere
to WGS84. For that purpose I need the +towgs84 parameters for my sphere,
which I
do not know. Does someone have a clue how to get these parameters?
Any suggestions will be appreciated.
Best regards,
Martin
Reply:
A decent datum transformation program should be able to transform from
ellipsoid-ellipsoid, ellipsoid-sphere, sphere-ellipsoid, sphere-sphere. I
don't know if PROJ.4 can do this, but it should not be too difficult to
implement this in the code.
A transform from spherical to ellipsoidal coordinates is not necessary for
some kinds of data, like meteorological data?
Hmm..... let's take a test point, say lat=50d; lon=10d; h=120m; on the
Normal Sphere with a (rounded) radius of 6371000 meters. If I transform this
to the WGS84 ellipsoid with translations 0, rotations 0, scaling factor 0,
then I get the coordinates:
lat'=50.1892244; lon'=10; h'=5558.1 m.
I should say that about 5.4 km height difference and around 21 km difference
in northerly direction (with respect to the WGS84 ellipsoid) is quite
significant.
Oscar van Vlijmen
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
