[Proj] API documentation for Gdal/Ogr with C#
Kyle Shannon ksshannon at gmail.com
Thu Feb 9 08:58:59 PST 2012
OGR api docs are here:
http://gdal.org/ogr/index.html
Check the read write tutorial too.
kss
 * Kyle Shannon
 * ksshannon at gmail.com
On Thu, Feb 9, 2012 at 08:19, Mustafa646 <noorcs22 at gmail.com> wrote:
> I want to assign projection to shapefile in my web C# application, for this
> i am using Gdal/OGR/OSR C# bindings and add osr_csharp.dll and
> ogr_csharp.dll references. But i am facing some difficulty while writing
> the
> code for assigning projection to shapefile. I want to know is there any API
> documentation for this which can help me to understand the classes/methods
> of these libraries. OR if anybody have some piece of code for assigning
> projection to shapefile , then it will be great help for me.
> http://osgeo-org.1560.n6.nabble.com/API-documentation-for-Gdal-Ogr-with-C-tp4379832p4379832.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120209/696ae65b/attachment.html>
