[Proj] Proj Release
Sandro Santilli strk at keybit.net
Tue Feb 21 00:53:45 PST 2012
On Mon, Feb 20, 2012 at 10:03:43PM -0800, Frank Warmerdam wrote:
> Two outstanding issues I'd like to address before a final release:
> 1) Resolve whether it is appropriate for us to have switched from using
> +datum= to a detailed definition in the EPSG init file.  The GRASS folks
> have raised cain (cane?) about this.
> 2) Build internal handling for +nadgrids=@null.  It seems most of the
> performance problem Thomas was seeing with projections in mapserver related
> to using an actual file for this null transformation.
Would distributing the Swisstopo shift grid for CH need to be considered
for this release or would everything end up in a separate package ?
I think it would be the gridshift itself and a CH init file with 2
projections in it (1903 and 1903/LV03, the only one using the grid)
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net
  `-o------'
