[Proj] Proj Release
Martin Raspaud martin.raspaud at smhi.se
Wed Feb 22 06:27:29 PST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 21/02/12 21:46, Frank Warmerdam wrote:
> On Tue, Feb 21, 2012 at 12:14 PM, Martin Raspaud <martin.raspaud at smhi.se> wrote:
>> Hi all,
>> Maybe I come to late for this, but I would like to add a feature for
>> supporting GOES-R satellite projection in the "geos" projection. I plan
>> to have this ready within a couple weeks, and it would be nice if it
>> could be part of the next release. Is there time for this ?
> Martin,
> Optimistically, I'd like to get 4.8.0 by this weekend.  If
> you can do it quickly, it can make it in.  It is also possible
> I won't get it finished on time in which case you would
> have a little more time.
Hi Frank,
Here is a patch for the aforementioned feature.
Two questions though:
- - How and where do I change the documentation ? I'm not sure I've seen
documentation for the geos projection somewhere...
- - Are there unittests I need to modify/add to ?
Best regards,
Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (GNU/Linux)
Comment: Using GnuPG with Red Hat - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJPRPtRAAoJEBdvyODiyJI4mUsH/0N9b5hpd2p9z5jNCrGATnP2
6DvknpVfVq84GD38ARx/2DDz3ETOEFHb7VhBMG8xItaOc7s68xZWzTYQmhS622Mh
+3ndCxHizjWqGT/aBywLXnSs8FNrzWKRknit5TOT6/FSYxLtqeswZ6g2HBW3Wa/J
ieF29jhkNRrs4Pw+fhrV3S84Gt0n702PuN3BXb1gKJYJJUnmptH+12nWXpTzaPGn
luneBu8MinPWmHvtrXsuZsd+L9iyJdJpJfm8P36gpSm8/DqbKIFLohxZEDI/TLF5
WFs5PVwMyzOfa/gmUaEtDn+a+jBFNfSg6DrS6kv/fiH1uUAKzlR2AxXp7bpfiyM=
=QATT
-----END PGP SIGNATURE-----
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120222/ce7f8240/attachment.ksh>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120222/ce7f8240/attachment.sig>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120222/ce7f8240/attachment.vcf>
