[Proj] How grids work in PROJ4
Thomas Knudsen knudsen.thomas at gmail.com
Sun Jan 15 05:58:33 PST 2012
2012/1/14 Michal Seidl <michal.seidl at gmail.com>
> - Mikael Rittri explanation helps me a lot, I was really for a moment
> confused by Frank's one
Mikael's clarification was, indeed, excellent and useful
> - Joaquim formula h = H-N is OK. But as Frank said +geoidgrids is only
> name and can be used for other height correction which is exactly my
> situation.
But please note that Wikipedia and leading geodetic textbooks
(Hoffmann-Wellenhof & Moritz: Physical Geodesy, as well as Torge: Geodesy)
use a different notation:
h: height above ellipsoid
H: orthometric height (which to an excellent approximation is equivalent to
the height above the geoid)
Hence: h = N + H
So following Joaquim's suggestion of +H and +h options is quite risky. Out
of context you can never be sure what is meant by H and h.
/Thomas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120115/5f135c97/attachment.html>
