[Proj] EPSG 7.9 Upgrade in Trunk
Mikael Rittri Mikael.Rittri at carmenta.com
Wed Jan 18 06:22:43 PST 2012
Not a prompt reply, but anyway:
I noticed that for the British datum OSGB 1936, gcs.csv in the libgeotiff trunk ( http://trac.osgeo.org/geotiff/browser/trunk/libgeotiff/csv ) uses
the 3-parameter datum shift
        EPSG:1195, "OSGB 1936 to WGS 84(1)", accuracy 21 m.
I would have expected the more accurate 7-parameter datum shift
        EPSG:1314, "OSGB 1936 to WGS 84(6), accuracy 2 m.
This is a special case of the ticket
        http://trac.osgeo.org/geotiff/ticket/33
and since the general case won't be fixed, I suggest that OSGB 1936
needs special treatment (in datum_shift_pref.csv).
> New "preferred datum shift selection" rules are also in place which
> will give preference to 7 parameter datum shifts over 3 parameter
> datum shifts
You mean that some 7 parameter datum shifts are listed as preferred
in datum_shift_pref.csv ?  Because in build_pcs.py, I couldn't see
that 7-parameter shifts are preferred over 3-parameter shifts in general (but maybe I missed it).
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Thursday, September 29, 2011 9:04 AM
To: PROJ.4 and general Projections Discussions; GeoTIFF; gdal-dev
Subject: [Proj] EPSG 7.9 Upgrade in Trunk
Folks,
I have upgraded libgeotiff, PROJ.4 and GDAL with EPSG definitions regenerated
from the EPSG 7.9 database.  New "preferred datum shift selection" rules are
also in place which will give preference to 7 parameter datum shifts over
3 parameter datum shifts are also in place causing a fair amount of churn
in the definitions.
The updates are in "trunk" for each of the projects.  I plan to produce
libgeotiff and PROJ.4 release candidates soon with the new definitions
so if you think you might have objections please investigate and speak
up promptly.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
