[Proj] Undefined subroutine &Proj::proj_init_plus
Martin Moore martin.moore at avbrief.com
Fri Jan 27 05:17:07 PST 2012
Hi, I'm building a new debian squeeze server and am getting the following
error when I run a (working under Etch) perl script:
(In Etch this was &Proj::proj_init but it appears to have been replaced).
I'm assuming the Proj.pm module is loaded OK otherwise I'd get a different
error.
Top of the script is
 use strict;
 use vars qw($VERSION @ISA @EXPORT @EXPORT_OK);
 use Math::Trig;
 use Math::Geometry::Planar;
 use DBI;
 use Data::Dumper;
 use PDL::GIS::Proj;
and the line in question is
$p->{pj} = Proj::proj_init_plus( "+proj=$p->{proj} +units=$p->{units}
+lat_0=$p->{lat_0} +lon_0=$p->{lon_0}");
Proj was installed using ap-get, so I'm assuming no further build steps are
needed.
I know very little about perl and nothing about Proj, can anyone help with
this?
Thanks,
Martin.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120127/842daf17/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120127/842daf17/attachment.gif>
