[Proj] proj4 api issue converting between state plane and wgs84
jdb1a1 jdb1a1 at gmail.com
Thu Jul 19 06:31:04 PDT 2012
No, I didn't.  I ended up using proj4 on the server side with the C#
wrapper that is referred to here:
http://osgeo-org.1560.n6.nabble.com/C-NET-wrapper-updated-td3841800.html .
 Interestingly enough, using the same projection strings with the C#
wrapper on the server worked fine!
On Thu, Jul 19, 2012 at 7:26 AM, stevejking [via OSGeo.org] <
ml-node+s1560n4989353h4 at n6.nabble.com> wrote:
> Have you tried using
> "+proj=lcc +lat_1=39.78333333333333 +lat_2=38.71666666666667
> +lat_0=38.33333333333334 +lon_0=-98 +x_0=400000 +y_0=0 +ellps=GRS80
> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
> Regards,
> Steve
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/proj4-api-issue-converting-between-state-plane-and-wgs84-tp4979285p4989353.html
>  To unsubscribe from proj4 api issue converting between state plane and
> wgs84, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4979285&code=amRiMWExQGdtYWlsLmNvbXw0OTc5Mjg1fDEwMDY2NzgzNTQ=>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/proj4-api-issue-converting-between-state-plane-and-wgs84-tp4979285p4989362.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120719/4311d2cc/attachment.html>
