[Proj] does proj.4 work with Hotine Oblique Mercator?
OvV_HN ovv at hetnet.nl
Mon Jul 23 02:59:47 PDT 2012
Re:
Rick Graves gravesricharde at yahoo.com
Mon Jul 23 01:21:03 EST 2012
The Michigan Georef projection was discussed & verified on this list around
the end of January 2007 and around the end of July 2006 (judging from dates
of my notes).
With my code I get for:
lat = 42.25; lon = -83.75; // decimal coordinates
the Oblique Mercator Georef coordinates of:
x = 685493.0527; y = 191370.6792; // meters
This seems to be about right. It is within the bounding box and it is in the
neighborhood of where Ann Arbor is, looking at the coordinates map on page
16 of:
A primer on coordinate systems commonly used in Michigan
David P. Lusch
Department of geography, Remote sensing & GIS research and Outreach services
Group
Michigan State University
sept 2005
http://www.rsgis.msu.edu/pdf/mi_coordinate_systems.pdf
Specifics:
Michican Georef uses one ellipsoid: GRS80, not adjusted.
I guess you should supply to proj an alpha (azimuth at center of projection:
337d15m20s), NO gamma (let the code calculate this (the answer should be
equal to alpha), set no_off/no_uoff (to make it a Hotine-RSO), units are
meters.
If you cannot reproduce my x,y coordinates, then there could be something
wrong with proj's omerc in your version/implementation.
Oscar van Vlijmen
