[Proj] rHEALPix bug & bug fix
Michael Speth spethm at landcareresearch.co.nz
Mon Jun 11 14:20:21 PDT 2012
Greetings,
   We have discovered a bug in the rHEALPix projection that causes lon/lat's in the polar regions to be incorrectly projected if the polar regions are shifted.  I have written detailed documentation on the bug, so please reference this for more information.  I have created a patch that fixes the bug as well as provides the test plan and supporting source.  I have also made available the binaries for running the tests for the HEALPix and rHEALPix projections (64-bit).  To test the bug, I've included the source to a standalone C application with an included script that should compile on a 32-bit or 64-bit system.
Links
Patch: https://df.bestgrid.org/quickshare/cae33e5e7caf3955/combine_caps_bug-2012-06-06.patch
Bug Documentation: https://df.bestgrid.org/quickshare/5c677519931baa0e/SCENZ-CombineCaps-2012-06-07.pdf
Testing Documentation: https://df.bestgrid.org/quickshare/d6b285865b34db70/SCENZ-ProjectionTests-2012-06-07.pdf
Test Binaries: https://df.bestgrid.org/quickshare/7364e5e560b6d60d/jproj4-test.tar.bz2
Test Source: https://df.bestgrid.org/quickshare/3ad729a5bf29e17a/jproj4-test-src.tar.bz2
Please let me know if there are any questions or problems.  What is the process for adding bug fixes to the main line?
Michael Speth
Research Systems Developer
Landcare Research
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120612/27ca6aa3/attachment.html>
