[Proj] Eric Miller VB Wrapper +nadgrids=
stevejking stevejking at talktalk.net
Thu Jun 21 08:45:05 PDT 2012
I finally got around to playing with this again. Installed Visual Studio C++.
And complied the current proj4 binaries using nmake. I've also installed
MinGW.
I'd like to recompile Eric Millers proj_api.dll VBA linker. Wonder if you
(or anyone) would mind providing instruction on how to use your makefile to
produce the proj_api.dll. Aside from changing the following:
EXTRA_INCLUDES = -I. -I../proj-4.4.7/src
to
EXTRA_INCLUDES = -I. -I../proj-4.8.0/src
--target=i386-mingw32
to
--target=mingw
and removing --mno-cygwin
I've added the path C:\MinGW\bin as an Environment Variable.
Do I need any other files, or to move any files?
What do I type? mingw32-make ?
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Eric-Miller-VB-Wrapper-nadgrids-tp3841233p4983048.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
